vcObject
A base class for all objects. A vcObject becomes invalid when the object it represents is deleted. Accessing properties or methods of such vcObject will raise a ValueError telling that it has been invalidated. It is possible to use "IsValid" property to check the state, without raising an exception.
Module: vcBehaviors
Children: vcAction, vcBehavior, vcCollider, vcSimInterfaceField, vcSimInterfaceSection, vcStatisticsManager
| IsValid | Boolean | R | Gets a value that defines if the object contained in this wrapper is still valid. |
